BertR
The set screws on the lay shaft carrier could be screws in too far and putting pressure on the brake plates causing it to over heat the discs
Please explain to the less knowledgeable....me.BertR said:The set screws on the lay shaft carrier could be screws in too far and putting pressure on the brake plates causing it to over heat the discs
I found it. Looks like the plastic gear plate still. Will i still need to order the metal one?Ice_2k said:Not sure why, it works for me. Here's a screenshot, search by that title:View attachment 7839
I think you'll find that doesn't include the platedsm600rr said:I found it. Looks like the plastic gear plate still. Will i still need to order the metal one?
That would be greatdsm600rr said:I purchased the belt drive. I will post photos when it arrives.
Thanks for that DSMdsm600rr said:Its coming from Germany, so its going to be some time lol. I did google translation, here is what the kit comes with:Included:
2x pulleys respect the grub screws of the toothed discs necessarily tighten screws securing screws or paint !
1x diverting pulley
1x timing belt HTD ( Made in Germany )
1x cover 2mm thick polycarbonate
6x VA grub screws
1x fitting instructions
I also submitted an offer for $74 and he accepted.
I will be buying this to go along with it:
http://www.rampageshop.com/store/p364/704568_%C2%A0_Blue_Aluminum_Gear_Plate_with_Bearings.html
