- Maryland, USA ??
Yes 2 per arm. One on top and bottom of the ballThese 2 round rings do both of these go in one arm. Because I have 4 of these rings
Never mind
Never mind
I didn't have any original. I built the baja from scratchThanks, they just weren’t seated right so I couldn’t get both in to put on top
Did you use the original screws for the lower shock the threading doesn’t seem the same
Need stiffer springs and oil in the rear shocks ?Got quite a bit done just a lot of little things to do could use some new fuel line stuff as a rock.View attachment 66867View attachment 66868
Ya the rear shocks are way to weak now going to check DDM for something stronger
I think I have 40wt in them now with stock ss springs. I think I might upgrade the rear shock tower also now that I did the arms it looks so puny now. I also have the Flm front shock tower.
