- Thread starter
- #61
It’s a diff oil issue. I want to keep the soft foams because it helps a lot in loose traction conditions but the center diff oil being so light is causing the power to unload in the front more than I wantThat's was perfect for me! That buggy could use some stiffer foams, seen them tires ballooning pretty bad. Love the opening clip in slowmo, of the 5ive t. Well done.
???Order up a couple spare diffs and keep different wt oils in them. That's my plan. You'll always be ready for what the track throws at you then!
im still waitjng for sexy women????
Well they are certainly not coming for you ????im still waitjng for sexy women????
Gotta do something mate, you could see it start to balloon. Then start scooting over to the one side before you corrected it. Did I mention I liked the video? ?It’s a diff oil issue. I want to keep the soft foams because it helps a lot in loose traction conditions but the center diff oil being so light is causing the power to unload in the front more than I want
You did lucky for you I didn’t charge the GoPro or you would have hated the videoGotta do something mate, you could see it start to balloon. Then start scooting over to the one side before you corrected it. Did I mention I liked the video? ?
?Well they are certainly not coming for you ????
? only made them for under the drivers window.Stars face forward mate, that stickers good for the left side only. Like the wrap, think it will stand out rather well.
I was bored.So bob, what was the fuss over you selling your 5ive B on facebook? Seen some odd comments.
