Rovan 305a
misterleon
EMPIRE RC
Lifetime PLUS!
PLUS member
Build Thread Contributor
Long Island, ny
Untitled.webpHey yall consider picking up this thing. I want to start a new build and ideally would like to end with a RCMax power unit. I understand that this will end as a $3k+ build but don't want to/ can't drop that kind of money in one go. so that plan will be to upgrade to top tier parts as they break or I get bored. for the price ($460 all in) I believe this would be my best bet, but obviously I'm a dummy so i'd like to get the groups input.
I picked this buggy up for my 10 year old and it’s been flawless. I changed out the stock radio and it’s been great. I called Rovan direct and got it for $420 shipped.
I mean, it can't be worse than my Baja. Go for it, hpi doesn't really exist anymore so I cant say support the original creator ?‍♂️ that is exactly what I had actually (mine was black). Back in 2015
great thanks for the tip ill give them a call before I place an order if I decide to go that route
that's my same thought process. Every original Baja is either extremely molested, has tasteless upgrades or $1100+.
Mouldings are a bit off so holes don't line up .....or diif wont go into a tr case..... coop and Zed both had different problems ??‍♂️
My integy transmission didnt fit what so ever (probably the same for the tr, seeing as though both are made for the HPI). Had to Dremel the chassis out, top plate didn't fit after that (a good 4-5mm off) , flm axles didnt fit in the diff at all , rovan difff didn't fit in that transmission case without feking with it.
If come to expect some modifications with parts. I had to grind down my tr chassis braces when I bought the rcmax chassis. Two common brands that just didn’t fit together. I’m not too bothered by it. Would you wait for a cheap original used Baja that may or may not need work over a new clone?
After all your waffling about the clone wars over the last few years you had a clone??‍♂️
Both my baja builds where from original hpi rigs?? one I used and upgraded slowly the other I stripped and rebuilt it (my twin)
I'd personally wait to see if u can get an original Baja because of the fitment bs, way bigger Issue than just simply grinding summin down sometimes. Rovan is a last resort imo, btw don't buy a purple first gen. They are shite.
Don't get me wrong . I'm not complaining. I'm just giving the op something to think about . He's planning on starting out with a clone and progressively upgrading . Pretty much what I did. It's better to know that some parts may not fit correctly ahead of time so you don't get pissed off when they don't go together correctly.
yeah I hear you did you upgrade slowly or all in one shot? im not big on huge elaborate builds right away I like to build slowly as things break or when I get big influxes of cash
