kgm5512
Is the pulse port? on the intake blocked off? Sometimes gaskets can block the portnope. completely dry
And obviously check to make certain the needles are openi removed the filter and tried starting it and nothing, not even a pop. I also removed the spark plug and i didnt see any fuel spitting out. the choke works properly, its not stuck
Well that would mean fuel to the carb/engine that is good.yes, i just reset them again just to make sure since its a new carb. With the filter off i can see fuel in the flap of the choke, im not sure if that means anything.
It is not that bad of a process to remove. I re read your original post. You said the engine felt sticky?that was one of my concerns, that maybe there was no fuel going in . maybe something with the piston??? i wanted to rule out all the easy stuff before trying to break it lol Ive never removed a baja engine just small nitro
Hmmm….Look in the exhaust port and if possible remove carb and look into the intake at the walls and see if there are any serious gouges.it does, when i pull its not smooth as when you pull without the spark plug. it's jerky and hard...i just know its definitely not as smooth as its supposed to be
I am trying to help as best I can with out actually having this engine in my hands lol. It just seems odd you have fuel air and spark and no ignition. Compression is the last factor needed for ignition but it runs at WOT… maybe the ring is stuck I’m puzzledi removed the exhaust earlier today to look inside specifically at the piston but i didn't see any dents...i'll check the walls
Check the flywheel it could have skipped the key and cracked advancing the spark timing too much that would explain the broken pull startsbrother...and i really appreciate it...im sure its hard not being able to look at it physically and like i said i've dealt with nitro and this is the first 1/5 scale. ...ive read so many other forums to see their suggestions to others and that's how i started to troubleshoot this thing, its just confusing me that it does not start having everything you mentioned.....
Do overtighten it when you put it back on or it can split. Sorry brother I have nothing else. Maybe take some pictures of the engine I’m running out of ideasI just removed the flywheel and checked the key and everything looks good. nothing broken or cracked
Anytime I can help bro!!It's all good, I'm also calling it quits for tonight but I'll definitely check it out tommorow and post some pictures. Thanks a ton though
