so i bought the ddm billet isolator block at the same time I bought my esp race ported top end kit. My issue is I was having really bad luck with the actual delrin isolator gaskets causing my carb to loosen up. Well my olimat pipe is coming tomorrow so I prepped my 5t for the new one coming so I took the old one off. My issue is when I took a peak in the exhaust port I can see some scoring on the piston from sand getting in there with the carb loosening up on each run. Mind you this was a total of 3 runs... i tried everything from loctite to trimming the bolts..ultimately I ended up eliminating the delrin and going back to paper gaskets and all is good... how likely can I politely point at ddm and say hey there's a problem here and I can feel that I have lost some compression from this and the kicker is i don't even have 2 tanks through this top end kit
