Bryan K.
So I have a DBXL and I 100% want to use the original canister exhaust, no exceptions. However, I'm having a real hard time getting a hose to stay on it. I've tried rubber, teflon and Silicon hoses and they all eventually blow off from the heat, pressure and oil. There isn't much metal to clamp on either, so it's actually a really bad design if it fact it was designed for a hose to be put on it. I've clamped down as hard as I can and usually what happens is the clamp strips out or the clamp gets so tight it just pops the hose out. My last resort, I grinded all the paint off the nipple and roughed it up, then JB welded a bead around the outside edge of the nipple. Hopefully when I clamp down on it, the bead will stop it from blowing off. Should work, I did this all the time on my intercooler pipes on my Turbocharged 1:1 cars. There isn't much room for the bead, but I'm out of ideas.
What have you guys who run the canister exhausts been doing? I feel like nobody runs the stock exhaust anymore. I just hate noise and I don't like the bulk of the tuned pipes. Plus I question whether or not they do anything. Usually when something is louder, it "feels" like it's faster when it actually isn't. Very common with 1:1 cars when ricer's add open style air filters and louder mufflers.
Also, how is the design of the original canister made to function? It just blows hot goo all over everything (servos, linkages, wires, battery box, etc)? Seems like a pretty dumb design.
