Spektrum dx5c w/ AVC
JACKDADDY83
Denver,Co
Hi guys I'm looking for some help I'm currently trying to run the spectrum DX5C with AVC but I can't find a kill switch that will run with AVC for some reason every kill switch I look for the AVC interferes with the kill switch do you guys know of a kill switch that runs with AVC please thank you
Can't you turn off avc? Don't know much about spectrum cuz I never run them.
You need two bind plugs to turn off avc then you can use the dynamite kill switch and the killer bee. Facts
No you can't use avc
How do I use two bind plugs? I'm confused don't I just turn off AVC on the transmitter or do I have to bind AVC out of the receiver with to bind plugs
Hmmm didnt know I could use power button as kill switch
ok ok restart, is ur radio a 3 channel? so here, plug the servos in the 1 and 2 channel as normal, plug the kill switch into the 3rd channel, and thne theres always a auxiliary or battery channel, plug the lights and battery/on off switch into the battery channel using a y connecter like the one in the photo download (1).jpg
You put one bind plug in the bind plug hole and one bind plug in the aux then turn on reciever your reciever should flash indicating that avc is disabled pull both bind plugs out... reciever should be flashing, then proceed to hook up your kill switch. Or call horizonhobby they have great customer service that's what I did and they helped me out
