Jimmy james
- Paris
Hello,
I have baja 5t and some reason it cut out the other day on the sand dunes. It never happened before so maybe you can help. I will tell you what I have done, couldn’t find anything in the search on the site so here goes.
Check the carburetor for dust and cleaned. Clean the filter in the tank to see if it was blocked as when I prime it, it only goes about to 1/4 full the prime bubble. Spark plug is good checked. But when I prime the bubble in the orange pipe leading to the tank there is bubbles, normal? I have yet to take apart the black pipe leading in the tank to see if that is blocked going into the carburetor. Checked for air leaks with WD 40 but found nothing around the carburetor. I’m thinking of talking the carburetor out tomorrow evening to check more in detail.
Thoughts all
Best
Thoughts all
Best
