T Bone racing 5T full skid plate
Its not a bad idea but hear me out first. The single piece front and rear skid plates we have are aluminum which means the screws that hold the front and rear suspension components above are more secured and less likely to come loose or pull out of the plastic diff housings. Now say you go with the plastic whole chassis plate now your unable to fully seat the chassis screws due to the screw wanting to push through the plastic and your not fully tightening the screws which can lead to the holes egging from the screws not being as secure. Just a thought
Its covers the whole bottom of the chassis. No added aluminum plates and no inserts to prevent the screws from pulling through the plastic so your not getting the proper "hold" from the screws.. just my opinion
Yes these are good points about the seating of the screws
I can't help my compulsion to protect the metal main plate its just an OCD I can't break and I already bought spare bumpers a "beater " set for mild bashing and new ones ready to go once they get used up
If I do go with the t bone full skid I may uni bit out all but a few of the holes so the screws are in original seat and the plate held on by less screws and some thin two way tape
Now I want some control arm protectors like I run on my rustler
Have you considered adding new holes in the chassis and bolting a piece of plastic over the stock setup? Like plating over everything while leaving the stock hardware alone. It would have the added benefit of protecting the stock screws heads as well as the chassis.
Something like 1/8 kydex would be inexpensive, easy to work/form with just a heat gun and easily replaceable when it inevitably gets worn out.
I use kydex a lot its strong and very easy to heat form, and cheap to boot. Like your idea about bolting it.up.separate to the chassis.
The middle of the chassis will be in good shape as long as you don't "roll" any jumps. It's mainly the ass end or the front that takes the abuse
Winter skid plate good for snow works amazing .
