throttle servo stoped work in 1st drive
Stock servos aren’t the best servos but they should def last a lot longer then 10’min...
Check all the connections, because something went wrong for sure.
you need to make sure the servo is aligned properly
And make sure you Set END POINTS correct so you don’t burn out the servo.
I have no idea how to set the end points with a stock radio, But I saw a video that explains it.
Here is the link, hope it helps.
My stock ones lasted quite a while and I have savox servos in it now again. Haven't had an issue. Well actually the stock throttle servo is fine it was the steering that went out on me.
