Ferrebee88
Hello again!
I recently finished my Vekta.5 build and have a few observations and questions after finally getting a few good runs in on it.
Suspension: I have the suspension set to factory settings. The rear end kicks up a bit easy and send this thing cartwheeling. I’m not sure whether it would be better to adjust the preload to make it stiffer or thicken the shock oil/change out pistons. It looks like I will need to replace the rod ends on the shocks as they are already stretched out.
Tuned pipe: Is this amount of rust from sitting for a month after running normal? Is it preventable? Should I even bother cleaning it off?
Observations: Check the screws after every run… I just realized I lost a couple screws that are holding the gas tank on… it dropped down and the driveshaft was rubbing on it and almost ate a hole through. I found an aluminum transmission cover, so I’ll give that a try. The lexan on cracked and broke off on the first run. The truck is fast and super fun to drive. There are some minor issues so far, but nothing some preventative maintenance cannot handle.
Engine: This ESP 34cc packs some power. After a few cartwheels it started bogging down and stopping, so hopefully it just flooded a bit or something. I believe the spark plug is the correct color. Maybe needs just a little richer?
