Two speed Monster.
Some interesting-looking geometry going on there!
It's worth bearing in mind.
I'm not having any problems so will stick with for now I reckon.
I'm looking at brake and wheel / tyre options for the New Year, so don't want to potentially compromise this just yet.
Alan.
get a set of fg tuning cable brakes on the back and hey presto good brakes
Alot of us guys that Drag Race over here in New York run FG Marders/Baja and we run anything from 19-20 tooth on the layshaft gear to 45-46 Diff gears. And on the two speed we run anywhere from 46/40 2 speed gears from 44/38 2 speed gears. Thats running the 330ft Drag Strip 4.3et at 76 mph and all we do is drill out the 2 speed hub and add two or three more set screws so the 2 speed claw have extra to grab.
and what off, marder/baja or monster....i had every ratio for my baja as there isn't really a stock set up...off comes with 46/18 and 44/20 i think and onr0ad 42/22 and 40/24 (or might be 44/20 and 42/22....look on hobbytheks site they have the ratios that come stock, i had truck slicks, baja knobbies and monster slicks so having all ratios from 48/16 to 40/24 was handy....never bothered with 38/26 cos needed a new hub and was way too tall anyhow for my use
Right guys,I have just put my single on and the clutch bell is banging its arse off ....not aligning. I have changed the ally spacers and still not symmetrical! Ideas please/
J.
Voo,
If it's anything like mine, I had all sorts of problems aligning the clutch bell mount when I changed to Al.
I've got washers spacing the mount and it's perfect now. No running problems.
Suggest just check alignment.
Good luck.
Alan.
Voo,
Good luck.
Alan.
Cheers Al.I'll give it a go today.
J.
Two speed sorted(happy man now!) 46/42 hardened alloy gears. Sorted it with a tip Bad Boy Hobby( cheers Pete) gave me in the "wanted" forum ,ready to go back on the truck now.....YIPP-EEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEEE!
J.
Post some pics later.
YEEEEEEEEEEEEEE_________________HAAAAAAAAAAAAAAAAA!:2guns::2guns::2guns:
J.
Oops,in my excitment I forgot to put the pics in.....
