Nothing like a good oil/ fuel thread.......
Kevin is that you?Yes you will need to drill a few small holes Welch plug has to be removed to get to the low speed circuit. High speed is just a inlet above the needle. Reset pop off at 12 psi . throw out the base gasket take .020 off the piston shirt. I’m running a special case with reads but on a piston port . Math is everything
If you want fancy 7075 parts I got them
you have most of the things needed all ready tigon fuel line e85 diaphragm kit . castor is sticky and it loves heat .don’t know if its worth the time and money I build go ped motors for rich kids that want to hurt themselves. seams like your sport is more about hand eye coordination tires and suspension
