Bryan K.
- Richmond Hill, Ontario
Hey guys, I'm having issues setting up my Fuelie 30.5cc motor I got from King motors. This carb seems to be a bit of an odd ball. I haven't been able to find much information about it. The few forum threads I've found around the net say to use the same settings as the WT-668. However, on those settings the motor barely starts.
So the idle sounds very low and the motor sounds like it's choking. At first I Thought it was too rich on the L needle so I leaned it out and it ran ok for about 1 tank. Then all of a sudden it died then wouldn't run again. Even when I got it started, as soon as I applied throttle it just died again. Pull the spark plug and it looked good, so I ended up richen it up a 1/4 turn on the L needle c-clockwise and the motor fired right up. Then proceeded to run it through another tank without issues. The next day, I could not get the motor started again. I had to set it to even leaner settings than I had originally then it fired right up again? I proceeded it run it though another tank. Towards the end of the second tank, the motor started to bog down and it died again. I could not get it started again. I feared that I leaned out the motor too much and killed it. However, while running everything sounded great. Keep in mind I have no carb tuning experience. I'm only going by what I've read and what the OBR tuning video on youtube says to do.
I pulled everything apart again, checked spark, checked the kill switch connections to the coil pack, etc. Everything was fine again. So my dad got involved since he had some carb tuning experience with chainsaws and snow blowers and told me to lean out the L needle almost completely. I literally had it to half a turn C-clockwise from the full closed position and it started up? The idle/RPM was insanely high. He said that meant it was too lean. So I turned it about 1/8 of a turn richen and the idle started to go back to normal with small pops like it was before. If I went even slighter richer than that the motor would just die. So that's only a little more than half a turn from fully closed. My question is why the hell does this carb run so lean? Unless it has some whacky stock oem carb settings that aren't like the other Walbro carbs and why does the L carb setting need to be constantly changed? It seems like every time I run the thing the carb setting needs to be changed or it eventually dies? At idle it always sounds ok, but after a tank of running the idle always seems to die because it needs to be leaned out or richened? It doesn't make sense. This isn't a nitro, I shouldn't need to keep tuning the L needle every time I go out right?
My 1/5 gasser buddies said just to get a Walbro 668 and call it day. However, I've read that the 997 is made for larger displacement motors and flows fuel better at higher RPM's whereas the 668 has lag due to slow fuel supply. I'd like to get the 997 running if possible. Any advice would be greatly appreciated.
I will upload videos of the last tank I ran it through before it died. Let me know how it sounds. I got it started again with the leaned out settings but haven't run it yet. Literally starts now with 1 pull. I'm just uncomfortable with how lean it is. Should I not be too worried about the L settings, as long as it starts and sounds ok? Is the H setting more important for overall performance and engine safety? Is L just for idle or is it more of a low - mid range type of fuel setting? My understanding is that the L needle will supply the same amount of fuel from idle all the way up to top RPM's. The H needle will then dump more fuel from mid range up. Is this correct? If that's true, then I'm concerned that the lean L setting will mess up my H setting by making my top end too lean as well. I guess you have to listen to the motor.
Here's a video doing straight fly by pulls
Here's a video of some random bashing around
