DX3 smart. I have no problem buying a better controller if this won’t work.Which dx3 you have ? New one or the old one?
Get a futaba in that case...
@k_h_d is the 5t just a 2.0 or is it the v2? Depending on the scenario you need a DSMR compatible transmitter for the reciever to turn on. If you have the v2 you need to call horizon and you can use me for an example that you can not have an avc reciever while using a killswitch they are not compatible and horizon knows they are not....request a sr515 reciever from spektrum and they should give you one like they did for me. My issue was I have a 2.0 I had range issues they sent me an avc reciever knowing I have a killswitch and they ultimately gave me the sr515 and its all good just no telemetry
did u plug in the battery backwards?
I emailed horizon. I will also call tomorrow. If I hold the bind button on the receiver and then turn power on, you are saying I should get no flashing LED until I bind it with my TX?@k_h_d that reciever is useless to you. Please call horizon hobby as they own tower hobbies . Tell them the reciever is avc and is incompatible with a killswitch they will ultimately send you a non avc reciever
You must hold the bind button on the reciever while turning the rig on. And then bind it through the transmitter... your led will flash rapidly when doing this signaling its in bind mode. Until its bound you will not have any led
I appreciate the help. And I get what you are saying. It should not flash unless in bind mode by pressing the bind button. That is exactly how my other RX works. This one just does nothing.Its a brand new reciever on the market but if its any like I have it won't show an led until its bound. So the procedure is hold the bind button first and while holding the button turn the rigs power switch on and then your led should start flashing. Then go into transmitter settings and hit bind then go full left return to center then full right then back to center then full throttle then full brake as you do this the led will flash as you do each motion to register end points.
Also snap some pics of this thing im curious to see a v2
