- Bristol uk
i use this calculator ?
http://www.premixcalculator.com
but your other pic is of the exhaust port .....and its so clean no oil?
I wouldn't use those. They swell very quickly and become quite inaccurate. Great for storing mixed fuel but you'll find that they rapidly start holding more than the advertised amount.I use this ALM mixing bottle. Seems pretty accurate. I'm in Canada, so we use the metric system
Maybe the 997 carb isn't working properly on the H needle. It fires up every time with less than 3 pulls. It smokes off the line like it's supposed to, just not at the top end.
BTW, is there any issue with running these things for more than 30 min straight? Our group normally does tarmac auto-x style races where we literally run 30 min non stop around the course. I never check engine temps as I assumed they were made to take it. We have a long straight where there's a WOT pull for maybe 5 seconds.
Just was rereading this post and noticed you mentioned about blow by, as a two stroke used the piston to force the air fuel mix into the cylinder you would notice blow by like in a 4 stroke, when the ring gets to that point of wear, normally performance starts to suffer and compression starts slacking off. I think the smoke at WOT your seeing is just a good carb setting. A tad ritch.I should have mentioned that I also have an HPI Baja which I bought used. The motor looks old and I have no clue what it is. It pulls hard so it must be at least a 26cc CY with a 668 carb. I've run about 8 tanks through it now without any issues using the same gas/oil mix that I've been using on the DBXL. I don't think my gas/oil mix is the issue. I measure all my mixes uses that ALM mixing bottle and I make sure I'm precise with it. I notice my Baja smokes at WOT in the top end while my DBXL doesn't. It could just be blow by from the old baja motor, but still seemed suspicious to me. Maybe the 997 carb isn't working properly on the H needle. It fires up every time with less than 3 pulls. It smokes off the line like it's supposed to, just not at the top end.
We've determined that much, just would like to see a few pics of the blown up.parts to narrow it down a bit more. Kinda like baking a cake blind foldedHe blew 3 motors it's either the carb the gaskets the manifold fuel mixture or the spark plug. ignition coil
