Which gear set for Vertigo Transmission?
Ferrebee88
If I get the Vertigo clutch carrier unit, upper brace, and rear carrier plate... which gearing set would be best to start with (for general driving). I will most likely be using the ESP Ported Zenoah G320RC 31.8cc 4-bolt engine with a victory pipe. I HAVE NO CLUE WHAT I AM DOING AND AM LEARNING AS I GO!!!!!
ESP Ported Zenoah G320RC 31.8cc 4-Bolt Engine​
VGS1724 17T/24T
VGS1823 18T/23T
VGS1922 19T/22T
VGS2021 20T/21T
Believe it or not it's the stock gearing. I did a build thread on the vekta .5 with the absolute minimum to be a good rig.
I'll check out the thread. I'm ok with putting down some coin if it makes sense in the long run, but I don't want to spend it where it is unnecessary.
Think I have 19/22 in mine with an esp 34 in it. It's a nice mix of torque and top end.
Is this one of the "go to" engines for this rig?
ESP Ported Zenoah G340RC 34.02cc 4-Bolt Engine.
I honestly don't know the difference between the normal 34cc and the 34cc ported. Is there a huge difference between the 32cc and the 34cc?
Porting and a proper pipe makes it all come alive. Do the 34cc race ported esp engine and a vrc unsilenced pipe and you'll be very happy with it.
Sweet. I got the VRC pipe on the way (it's the DDM deal of the day right now). When the time comes I will get the 34cc ported. Anything special I will need for putting it on the rig that isn't included?
ESP is the most economical way to achieve 34cc.
Port work costs money. Takes labor. Increases the price.
Save your money while your building and get the taylor 35. I think you would be happier with that engine.
I have the same esp engine you speak of. Heres you some eye candy.
