- Reaction score
- 27,691
So I go to start my Baja today, it starts up like usual, 4 slow pulls on choke and then a couple fast pulls. Starts right up and runs properly, then after a few minutes idling, it just randomly stops. I raise the idle and start it up again. At this point I figured something might be up . So I go to drive and it won't idle, I have to rev it to keep it running, and if I don't ,it will stop after a few seconds. Motors got compression, coil is tight, flywheel is tight. It also makes a wierd, kinda rubbing sound, not quite a clank but it's like a bolt rattling around type sound. So what could it be??? Maybe a clutch bolt backed off? But would it stop the motor from running?? And the clutch still engaged fine btw.
And at the end, I couldn't get it to start at all.
