G
Guest
Guest
Com'n together nice.
had to drill the shock towers just a bit (note that these are MT shocks). Used a calliper. just drilling couple of mm for the bolt to enter would do fine. (also, I replaced the shock oil to 40 wt)chapinb said:Do the resi shocks bolt right up? Or was there some extra hardware or modifications needed?
Yup they're the best. Very high quality. used for both front and rear.Sergio said:Looking good. Are gonna use FLM cvd's in the rear too I'm curious
That's sweet! I've always hated that is open under the truck bodies.Ol said:One thing I'd like to point out here. If you have an XT I can make the side guards 3 or 4 inch's tall to cover up everything you can normally see. If you trim it right up to your body nothing will go over the top, does a pretty good job of keeping the mud out.
Yup, they're easy to cut. will get to the steering part today.Ol said:One thing I'd like to point out here. You see in the pix the corner of the radio box is sticking out of the side guard. He cut that opening himself. He will have to cut openings for the steering links too. The side guards are made from ABS and it's easy to cut, that's the idea, you custom cut it to your car. Looks like the pipe is a little close too, no problem, trim it to match your pipe, looks good. If you have an XT I can make the side guards 3 or 4 inch's tall to cover up everything you can normally see. If you trim it right up to your body nothing will go over the top, does a pretty good job of keeping the mud out.
