Yes it has a g320 engine in it now
Yes it has a g320 engine in it nowsounds great ill flog this one then upgrade to the zen.was clutch bell and everything else the same.
which oilIs it bad I'm running 32:1 never had an issue
I'd hate to say it but super tech isn't THAT bad. I would use it on my cheap junk engines but it would never touch my OBRsI run amsoil dominator, but there are lots of great choices, just don’t use any cheap stuff, they tend to build up carbon and lack lubrication
what oil and ratio phill
They make a synthetic blend. Worked on my cheapo Rovan for almost 3 years but I may have gotten lucky with a good engine
40 to 1 klotz super techniplate. Have too many 2 strokes to mix different ratios. They all seem just fine.
Yeah idk about that. I largely think the high ratios are so the manufacturers can cover their arse. I have gallons and gallons through my old g320 with no issues. Same with my current 2 rigs, and countless saws. Which get a harder workout on any given day then any of our rc engines could dream of. Works for me.You're a brave man Sean![]()
Definitely, I’ve seen ppl runI largely think the high ratios are so the manufacturers can cover their arse.
why do we put so much oil i have a mowing business and everything is 50 to 1 so was my dirt bike.is it the revs or poor quality engines.
hey doug i sent you a text did you get it.??I run 28/1
Yeah it's a catch 22 comparing these to power equipment, they have overly strict epa emissions to deal with, and in part cause the high oil ratios. Rc is exempt from these standards, so the mfg don't have to worry about how much oil is pumped through the engines. There is a point where you can over do it, and with modern oils it's just not nessisary. Take our favorite zen engines. It still specs to run caster oil. Castor oil is great stuff but old tech, and needed higher ratios to perform well. Any modern oil that was designed for a modern engine doesn't need the high ratio to achieve excellent resultsDefinitely, I’ve seen ppl runto 1, now obviously I would highly recommend against that, but I think some tmr guys especially run 50 to 1. I wouldn’t go under 40 tho.
