- Thread starter
- #481
No idea how.to do that ? I'll check the vid. I'll ask Sean if they mod it themselvesMod the stock ones your self?? seen a YouTube vid??
Ok I'll check it.YouTube ezeetrader rc he ports a 32 rovan.... and he dose port covers??
Thx. That's super cheap! I might have a pet leash somewere that I might be able to use ? I'll see.@Z.hb71 posting here as this is the relevant thread. It's super easy to build suspension limiting straps using nylon webbing, or even cheap leashes from the pet store.
Here's a great vid to show you how to do it under $20:
NVM I don't have one but theyr super cheap.That's exactly what I was thinking of using ???
Ok next time I'm/were over there I'll pick some up. Hopefully they have sum in purp ??You don't even need leashes. You can go to the nearest craft store and get some nylon webbing in pretty much any color for super cheap. I just wanted to provide the video as a starting point. There's a lot of possibilities here for creativity.
Yeah but 9hp is better ??The piston port in my losi ? and it rips ??
Yep both haul ass from what I see ??It is but if you can only the piston port ......it will still make you smile?
Alright so change of plans. On my parts list I was Gunna get kraken clipless hinge pins, well I personally think that's a. Total waste of Moneym sure they are hardened and are clipless (duh), but 65 is hella $$ for those lol. So with the extra $$ im Gunna go for this instead of the 34 piston port
http://www.oneillbrothers.com/rc-ca...-mod-zenoah-g320rc-31-8cc-long-block-859.html
Will rip ? almost the same as Doug's motor in his kraken sx5 and what @AnubisBC just installed into his Baja 5t, just this is a 32cc, doesn't have the +2mm stroker. Which means more rpms ?
Baja that ain't a problem ?Bought the piston port coz I didnt want to hack a hole in the side of my shell?
What?You can get wall hangers a the dollar store!....
No that's why I stuck a reed in my hpi??Baja that ain't a problem
