- Florida
Try a new spark plug Before you go crazy taking it apart
Already did. And just redid the gap an it made no differenceTry a new spark plug Before you go crazy taking it apart
??? Was leftover from me first Baja ?WHAT, ROVAN PARTS FOR Z?? In the video you were using more Rovan parts??
..y brake the habbit of a life time ?WHAT, ROVAN PARTS FOR Z?? In the video you were using more Rovan parts??
Was 2-3 yrs ago ffs ?..y brake the habbit of a life time ?
Yes I turned off all the lights and obsoletely nothingMmmmmm check the carb bolts and head bolts??? bad seal on either will give a no start? have you pulled the start with the plug out to see if there a spark? Sometimes it very faint so do it in a dark room/space??
Probably ?? not surprising but I didn't expect it ? hopefully I'll be able to order one by the End of the week ? good thing is, we are not even in spring so it's not really a delays?Coil is feked???
Iv got a few cy coils and they also work ok?? costs a bit lessProbably ?? not surprising but I didn't expect it ? hopefully I'll be able to order one by the End of the week ? good thing is, we are not even in spring so it's not really a delays?
$7How much is shipping though
?? Sorry Zee i thought you meant the redneckgapped properly and all that jazz?
And BTW, no, the Shredstack will not work with the Uni filter. It's designed to work with the stock HPI filter housing. The ring from the filter assembly clamps everything together. I have one an will be happy to take some extra pics so you will be able to see what I mean if you want.
Yep it's on the 3rd channel, led shuts off and turns on when I press the 3ch button.What always gets me is channel 3 switch on tx. Did you check that?
