DID you try pulling the cord plug out to see spark?
Yes, no spark. I grounded it and noneDID you try pulling the cord plug out to see spark?
Yep. Are coils sensative enough to where a flywheel rubbing it would fek it?,Try a new plug ?
Wouldn't have thought so, the bolts backed out of my coil and it wouldn't idle or run but would start. After an hour decided to pull the covers off to have a look, bolts backed out, coil had been rubbing on the flywheel. I put bolts back in, gapped using business card and it fired right up.Yep. Are coils sensative enough to where a flywheel rubbing it would fek it?,
Ok I'll give that a go. I'll also Clean the flywheelWouldn't have thought so, the bolts backed out of my coil and it wouldn't idle or run but would start. After an hour decided to pull the covers off to have a look, bolts backed out, coil had been rubbing on the flywheel. I put bolts back in, gapped using business card and it fired right up.
I would clean up the face of the coil incase its contaminated or has build up of aluminum on there and try again.
17 be but yes.Aren't you using the $10 "Zenoah" coil?
That might be your problem. Your now up to the price of a genuine Zen.17 be but yes.
No,Im still at 17, the rov coil was free from 2 yrs ago lol.That might be your problem. Your now up to the price of a genuine Zen.
Not if you have to buy another coil.No,Im still at 17, the rov coil was free from 2 yrs ago lol.
I really don't think a cheap coil would cause that. The rovan lasted 6 months before the motor blew. I think it's the fact that it got knocked by the flywheel. IdkNot if you have to buy another coil.
No, its not hot. Or as mike would say NINHIts feking hot my son ?you could learn somin????
20/1 doin it probably. Lean your mixOk so it feels like the coil is fine. I can feel the spark and it feels strong. So I think my brand new plug just might be fekd along with the old one
Which is better than a new coil
What was it?Fixed now ?
+1??What was it?
