well i put the bike on the shelf for quite a while. had alot of thing to get done, get the home winter ready, work.. ect.....
so i have this week off, so i thought id re-visit my
Lose the battery box Mod.
heres where im at atm.
if all goes well with the design/fit, i ll have some made up out of CF.
again the goal is to lose the lower battery box, which will increase suspension travel by at least one inch of additional travel. im also working/hopeing this will help RE balance the bike. The Gyro system in the rear tire really makes the bike ass heavy, especially when airborn.
im hopeing by dong this mod, and setting it up the way i am, it will improve overall flight handleing, as well as normal driving charecteristics.
heres a couple quick pics.
here is the stock plates
here is a pair of new plates
and here is a small comparrison between the stock and the new plates
once i have it all together and it is seemingly doing what it should, i plan to offer up a kit to upgrade the DX450/M5 bikes to a new, better setup.
ok, chassis plates are cut and matched nearly perfectly. couldnt help myself, i had to see how they fit up and how the pack sat in them. i must say, im Very happy with how it is. i can see one change i would like to make, and it can be done during the cf cutting. these 2 will work Great for testing out.
on with some pics
will be making new upper rear chassis plates tomorrow, providing im off that is.
got the rear uppers cut and installed. its basically ready to test run, but i have to make a bottom plate to hold the battery up. i ll be trying to make a piece for that tomorrow to use for testing (just to hold the battery from falling out.
today, i ll concentrate on the lower battery compartment lid.
Keep in mind, this is all for testing purposes only. I have another idea for makeing this a quick, simple, mod kit. I believe it will work Much better than this setup im working on, but i have to have one part CNCd for me, before i can give that setup a try. But if it works out like i believe it will, it ll be an Easy mod to install/use, will make swapping battery packs easier, as well as offer the improvments in handleing i think it will make.
now i just need to find someone local with a CNC that can make the part i need.
