kreb
- amherstburg on
this is the one i use it is by dimension engineering and retails for $38.56 cad
Modified Pico Failsafe (tt554)
Modified Pico Kill Switch. This is a stock Dimension Engineering Pico Switch that has been modified for large scale R/C use. This amazing little gadget will do everything you want in a failsafe. The engine will kill if:
Transmitter is turned off
Transmitter is out of range
Servo wire is cut
Battery gets disconnected
You will need to connect a wire between the pico switch and the kill switch connections on your motor and set the third channel on your radio system to be used as a 2 position switch.
Requires a 3 channel programmable radio system.
i tried to copy the photo also but it won't let me for some reason.
Servo wire is cut
