Scruffy
Should be a beast regardless?Good question. Mostly a guesstimate, this cyl was dynoed at 17.39hp on a scooter, soooo I'm going to be running e85 which add alittle, also don't forget to remove drivetrain loss cuz rcs have wayyy less drivetrain loss than a scooter. A scooter has about a 5% drivetrain loss so add that. When I first run it, it will probably "only" make 12hp cuz I'm using a small 19mm carb, once I switch to a 25mm it will open it up alot. I'm Hoping for 20hp, seams realistic to me but I could just be delusional lolView attachment 47754 that's the Dyno sheet for the cylinder. Mines the red line, mk1. This Dyno sheet is for a rebranded 1. They now have a mk2 but it was out of stock.
