Are they those little fg tires/wheels? If so I agree, wayyy to smallPhil has a set on his but, Imo, I think they're way too small. Hurting his top end speed too.
Not sure but at least half the size, look funky on the 5B.Are they those little fg tires/wheels? If so I agree, wayyy to small
Get em anodizedMan, I wish those shocks r black.
Nay. I'll use dirt instead. ???Get em anodized
???Nay. I'll use dirt instead. ???
Probably 27.5, but u probably wouldn't notice a difference between the two.Which motor has higher rev, 27.5 or 30?
Debating on which to make a full on road. My new 30.5 5B should b here on the 2nd.Probably 27.5, but u probably wouldn't notice a difference between the two.
I'd make the 30.5 a road car cuz higher top endDebating on which to make a full on road. My new 30.5 5B should b here on the 2nd.
That's what I was asking.I'd make the 30.5 a road car cuz higher top end
Here I'm warning u on the gear set, make sure to heat up the pinion to melt the loctite cuz if u don't ur likely to strip the screw and that's not funAlso 20/54 gear set arrived too. Too tired to swap them.
Thx.Here I'm warning u on the gear set, make sure to heat up the pinion to melt the loctite cuz if u don't ur likely to strip the screw and that's not fun
20/54 gear set is going on my 36cc SCT.If you are going with 20/54 gears, then i would definitely go with the 30.5. I had a full mod 27.5 in my baja and it struggled on takeoff with 19/55 gears. 27.5 will give you higher revs which equals higher top speed, but it wouldnt have the hp to pull 20/54s very well on take off
Never seen that 1 b4. My rovan 30.5cc had the normal cb like the hostile uses. Maybe the RV 36cc Baja has the upgraded hax cb?So much for swapping to 20/54. Hostile set is not the same as RV, maybe KM too. ???
Looks like I have to order a new clutch bell. ?
?? exit stage left.I'm about to exit this forum permanently. My last 2 posts were moved to obscure places on the page. When attempting to communicate about it, all I got was attitude from a guy who clearly doesn't 'get it'. One of many reasons I prefer the Facebook pages. Everything stays put there and has 50 times the content.
