- Crafers South Australia
Tr all done up looks like a nice bit of kit and if the rovan gives out you could just get a tr diff
Tr sells a complete diff?Tr all done up looks like a nice bit of kit and if the rovan gives out you could just get a tr diff
Not sure i just assumed so ? if they make a case why not? Also seems odd that the hpi sapes would not fit and for that reason im thinking there are alternative options
Looking good ?And the rear end is back together yea !
Yeah that area is always a PITA to mount, especially my ALX case (was test fitting it) you have to push it into a wired spot to get it to line up. What I do is leave everything loose and just push in and out and keep my eye on the hole and see if it lines up.Now the real work begins . Decided to mount the engine into the chassis . None of the holes lined up . WTF. I had mounted the upper engine mounts to the new engine thinking that would shorten install time . So took both of them off and tried again . Got the the engine mounted with the 3 screws that come through the bottom plate . Cool . Next up the starter side upper mount . Its slotted and it went together and attached to the Upper tranny plate. So the culprit is the Clutch side upper mount . It is too thick in a couple of spots . So tomorrow I'll take the part to work and sand it down in a couple of places and see if it fits . I'm not sure yet but I may need to grind and edge of the tranny plate next to the brake . Not sure yet .
So in the mean time I pulled the rear half of the buggy off to make life a little bit easier to work on . The red square is the issue area .
???After I get the mount fixed I'm wondering how much trouble I'm going to have mounting the Clutch bell and plate . Will probably need to loosen everything up to get those parts in . It wasn't easy getting them in and out before the new tranny and engine . It's ok though I got a really big hammer .
??After a little sanding & grinding the engine is in and mounted and I got the clutch bell and bracket setting in place .
Awesome
Was the bell carrier touching the bell?
