Pics of your favorite builds and engines
Wow! That guy has a collection! I couldn't pick, there all badass!
Take a look at the edit I made. His cars look pretty standard'ish FG/ELCON type buggies but they are not. About 400 hours goes into each and they are unique. If he gives them a name such as FG, its if he lifted most of the design to fit within a certain class. Everything however is improved upon. Once you start to look at the details, the work suddenly stands out clearly. All the little details. Kind of like how Chip Foose handles hot rodding. Make it better than the original but make it look like the factory intended it to be that way.
@Milo Kraken tsk baja, looks sick! this, 1coopgt, and jackdaddy's bajas have to be some of my favorite small block baja's!
49984
4998549986499874998849989
Here's the parts list
Kraken TSK1 Cage
Kraken V3 Chassis
Kraken Upper front hinge pins
Kraken Stainless Steel front shock shafts
Kraken Titanium Rear shock shafts
Kraken billet rear cage mounts (not fitted yet)
Modified RC rear chassis plate
Custom carbon sidepods
Threshold rezzies V2
Threshold Umbrella seals
Thicker o rings in shocks
DDM HD rear springs
HPI Standard front springs
Team Chase rear shock towers
TR Front chassis plate
TR Front shock brace
TR Steering servo saver thing
TR Rear top plate
TR Gearbox
TR Clutch V2
TR one piece brake mount
IRC Differential
DGI Steering turnbuckles
IRC Steering posts
Swingy P limit straps
RPM front and rear suspension arms
RPM rear bumper with modded HPI 5T rear bumper
IRP Heim joints
Fullforce Spring stand off's
Fullforce Shock socks
Reinforced bolts for hinge pins
Hostile adjustable rear hubs
Fast Eddy bearings
Fast Eddy front hub cone things
RS Fruitbat axle extenders
RCR Brakes
Bonehead RC chassis braces front and rear, hinge pin things
Bonehead RC Rear boot protectors
Phatdad Rear hinge pin brace anti squat 2 degrees
Phatdad engine and chassis braces
Phatdad dogbones and cups
Gabe Brown Engineering rear engine brace
HPI PCSC modded to accept any gears
Custom Titanium layshaft for the PCSC
Golden Horizon front hubs
Golden Horizon Rear shock brace
Golden Horizon front bulkhead, rear shock towers, supports rear A arms, front 5T body mounts. (Not yet fitted)
Killer RC clear Battery box lid
Killer RC power switch
Vapetex Life batteries
Futaba Tx/ Rx
Futaba RPM Sensor
Switchblade kill switch
Savox servos
Silverback wheels
Proline tires
UBER RC wheel nuts
Scott Finlay Pro MX 340 with mesh mod
Bartalone Torpedo exhaust
Bartalone coil spacer
MSD coil wire
Stage 8 header bolts
Team Chase Carb filter
Billet intake manifold and teflon gaskets
FID fuel filter
Outwares allround
Titanium fixing screws
Full kill throttle and brake linkage
Wow, i'm just blown away at the functional engineering that these Large scale guys have put into their rides ! My long term plan is to convert my LMS mini mill to CNC then build a vicious large scale liquid cooled ! ?
LMS mini mill ???? What's that ? Just wondering , how are you planning on pumping the water ? Small electric pump?
There are PC cooling pumps that could handle the job in terms of volume and some of the radiators have enough surface that with a couple of Noctua industrial fans, ugly as they may be, could probably handle the job. Being tossed around in a basher however... well its definately outside of factory specifications and the warranty will probably not be available if you break something and tell them the truth. Except Noctua. They don't want their fans to fail, period. So they have a rep for just handing over new ones to squeeky wheels no matter what stupid poop they had been used for that they were never intended to.
