- 27,691
Do piston stops work with domed Pistons or that Pistons? I've heard that if you use a piston stop on one of the tho it will punch a hole in ur piston
I dunno was something i hearddon't see why it wouldyou put a wrench on crank and turn it by hand.......
Unless you the size of a brick Sh!t housedon't see how you would punch a hole in your piston
and even if you were that size still cant see that happening
???So you built like arny?![]()
that's not the problem....its the stress u put on the bearing ...imo......Do piston stops work with domed Pistons or that Pistons? I've heard that if you use a piston stop on one of the tho it will punch a hole in ur piston
U talking about a clutch tool? Standard clutch tool couldn't work but I think I could rig something up ?I got a feeling we went through this a few months ago on another thread? some one got all but sore about them and posted about some for other tool.....help cant remember what it was. May be a better option for all the $ you've spent. don't want screw it up.
No wouldn't work, my clutch drum is wayy bigger and different. I could probably rig something up ? I prefer that method instead of a piston stop.Found it.... don't know if it apples to your engine in particular
https://www.largescaleforums.com/threads/dynamite-clutch-tool.22981/#post-216956
I have a clutch tool for my alx, comes with all complete engines from Alex. I can show you of you like?U talking about a clutch tool? Standard clutch tool couldn't work but I think I could rig something up ?
Will do in a bit when I get home then DougGo on shown us
Yes I'd like a photo plz ?I have a clutch tool for my alx, comes with all complete engines from Alex. I can show you of you like?
Ah ok, I think I could replicate that for a 54mm clutch ?
Yeah should be easy enough ?Ah ok, I think I could replicate that for a 54mm clutch ?
