- 27,691
Mkaaaaaaaaayyyyyyyyyyyyyy i need suggestions. SO a little back story, on my custom engine, its custom (obviously) and with that nothing is preset or has a specific requirement, basically, everything is up to the builder. and that includes ignition timing. soooo I don't know where my timing is supposed to be at so i will be making a custom adjustable ignition system. hers how i explain it https://www.largescaleforums.com/threads/custom-70cc-engine-build.22765/page-20 so my problem is my flywheel is too thick and doesn't allow enough back spacing for my gears, soooooooooooooooooooo i want to remove 5mm off the back/bottom of the flywheel so i will have enough clearence, will this upset the balance? it will be with a lathe so it will be even all around. IF it will screw up the balance, what should I do for a flywheel?? I was thinking of removing my flywheel and replacing it with a clutch plate (yes a clutch plate), put a small magnet on it, and use that as a flywheel. But I want other suggestions. Oh and also, my engine doesn't use a cooling type flywheel, it just doesn't need one. SOOOOOOOOOOOOO i want suggestions for a flywheel substitute. i don't wanna make one.
