- Crafers South Australia
Right only really clicking now about your question/issue ? the mounting post on your head has been grounded off...... must have done that when red arrow trimmed the fins you should put a coil spacer against the head it will stop the shroud from melting??I did the old double nut trick! Worked perfectly!
She’s all ready to drop in!
Just looking at some ddm pics of your motor this is the back end . Can see where the coil bolts on... and where they stopped grinding. if you look closely looks like the crank seal was in when the sprayed the block........ was yours a complete motor or just the block? Did you see your seals?
