Darnell
Looking to replace stock clutch on 5t 2.0 G320RC, manual is calling for 54.99. Is there a cheaper way out?
I'd go with a fs clutch, lasts longer, and cheaperLooking to replace stock clutch on 5t 2.0 G320RC, manual is calling for 54.99. Is there a cheaper way out?
Yep 54mm ?54mm?
Thank u Z.hb71
I'm not entirely sure, I've never broke one it, but I'm probably doing it wrong then, somebody could tell you ?They say there is a break in period on those? What do u say?
Yea I just looked at that one, I’m thinking that’s the stock one, the part # in the manual calls for some expensive stuff I thinking cause it bears the losi name. Thanks mark35I've not used a fs clutch either but here is a zenoah clutch.. http://www.davesmotors.com/zenoah-54mm-clutch-shoe-and-spring-kit-8mm-hole-for-mount-bolts.html
Engine is a zenoah, most likely zenoah clutch, losi probably rebranded it and just charge more cuz it says "losi" on it ?Yea I just looked at that one, I’m thinking that’s the stock one, the part # in the manual calls for some expensive stuff I thinking cause it bears the losi name. Thanks mark35
+1 they are good??I've not used a fs clutch either but here is a zenoah clutch.. http://www.davesmotors.com/zenoah-54mm-clutch-shoe-and-spring-kit-8mm-hole-for-mount-bolts.html
Good information, I might as well use the stock one it’s 13-17 buck and would be cheaper than replacing metal. Thanks losi125I just want to put this out the fs clutch seems great it wore out my stock clutch bell upgraded to a bartlone clutch bell installed and re checked the clutch bell about 6 or 7 runs maybe more and I discovered it was wearing the bortlone clutch bell I could feel a grove on the inside of clutch bell so now I'm on turtle racing clutch bell haven't checked it since install maybe 4 runs it's an excellent clutch stronger than clutch bells if it goes through the turtle I might go back to stock or get a snapper or mip clutch
Cant go wrong with that?13-17 buck
