- 27,691
I'm pretty sure the crank goes clockwise but just to be sure, cuz I'm using a drill start and I want to make sure I set it inthe right direction
Yeah clockwise Zee??I'm pretty sure the crank goes clockwise but just to be sure, cuz I'm using a drill start and I want to make sure I set it inthe right direction
ThxYeah clockwise Zee??
Well my comon sense has left the chat ??View attachment 52175
Same direction as the arrows on a clutch???
Its anti clock wise trust me we've been over this??My tip for easiest way to verify is look at the pull start cover . Note that as you are facing the PS housing the rope exits the housing on the left, so when you pull up on the rope, that causes the PS pulley to rotate the crankshaft clockwise. That being said , looking at the clutch side it's opposite and the crank rotates counterclockwise.
Thats not the business end but the clutch is the end that counts?If by "anti clockwise" you mean clockwise then you are correct ??View attachment 52393
To start the engine with a drill you will need to run the drill forward and not in reverse
So the way to make the clutch actually spin is the end that doesn't count ?????Thats not the business end but the clutch is the end that counts?
Ok can we stop bullshittin on this thread????? Clutch side is anticlockwise and flywheel side is clockwise, done? Done.why would they bother with the arrows if it did not matter??
Haha.. Yes, as you wanted to know so you could use a drill start then forward or clockwise is the direction you want the drill to be going??Ok can we stop bullshittin on this thread????? Clutch side is anticlockwise and flywheel side is clockwise, done? Done.
Awesome ??Haha.. Yes, as you wanted to know so you could use a drill start then forward or clockwise is the direction you want the drill to be going??
Hahahaha. Stop it doug ?Ok could not help my seft??
