Ok I need to ask something, I'm installing the piston circlip I'm wondering, there's a notch in my piston and my cir clip is almost a full circle with a break in in, do I have to line up the break in the circlip to the notch in the Piston?
Here is the circlip
thers the notch
And here is the circlip installed, as you can see the edge of the break in the clip is lined up with the edge of the notch, is this correct? I'm pretty sure it is, but just to be sure, don't want a clip flying out and fekin everything up
Edit: I hate to inform you guys, that this 70cc will not be done today or tomorrow or the next day, I have uncountered a issue were the crank is not allowed the go all the way to bdc becuase the piston hits a section of the crankcase, so the crankcase will need to be modified. I had no idea that this problem would arise becuase I have no means of testing this till today because I didn't have bearings in the case or was ready for the piston. ??????? so theres another week or 2 onto this whole ordeal.
Edit: ok maybe I have a plan, I'll buy a poopy $15 rotary tool and hit the case with it after I take it all apart, a very very very annoying delay and I should have checked it before it's half assembled.
