$2000.00 into a heath kit is nuts! Now We know you are a Kid at home , Show woodie your ID so we know how to respond to you LEGAL !Care to Explain?????? First, not using a starter cu, going pull start, second, that flywheel should be just fine, if not then explain. If it blows apart than so be it, custom flywheel will be made. Third, there is zero slop in my flywheel and ignition setup, wouldn't have proceeded to try and run it if it had because I'm not about to half ass my $2000 plus build. And lastly, I don't appreciate you calling my build a "joke" with zero explanation and you don't even have a single post introducing yourself and showing off your rig instead of coming at long time members for no reason.
