hpi diff
Totally gone, pretty much impossible to find those gears. Totally sucks. Hpi needs to get their poop together. Next option is clone crap but nothing fits together correctly as coop said. Someone needs to remanufacture them or make a stronger version (not really required tho as those gears rarely have issues unless they have a Alx 85 or 80 supreme in from of em) .the baja is pretty juch dying cuz of hpi not making the proper stuff, now we're stuck with sub par clone stuff that never fits right ??
Thanx jim I'll check them out??
Dougstar I am not sure if you would want to go this route but GreatHobbies here in Canada lists a complete HPI HD diff in stock for $158 Canadian..
did you blow up your diff?
I've only heard of people blowing the case, but the gears are pretty bulletproof.
No my diff is all good with genuine hpi bevel gears?? want to build another rig????
Have you checked dollarhobbyz. They generally have all the HPI baja parts in kit form and theyre relatively cheap conpares to other sites. When i looked they had the whole kit for around $75. Check it out
https://www.dollarhobbyz.com/products/hpi-racing-1-5-baja-5b-ss-differential-kit
They run out of stuff pretty quick but if you sign up they will send you an email as soon as they get it in stock. Usually a couple days is the most ive had to wait. Good luck
Search "hpi baja diff".
Ton of parts for ya
