Show a pic of your setup maybe. And yeah you could probably limit the shocks that way, I did that with my rustler a looonggg time ago. Have you changed the camber settings at all? Cuz too much positive camber will likely cause this.Was told that , But thought it was for not ripping the cap/ends off ? Looked for the killer ones but it looks like they are no longer to get. Do you think if I put some spacers inside the shock bodies it would do the same thing?. I have aready put o-rings in cups to center the bones but they still pop out.....Stumped.
the only thing I upgraded is the arms. I went to RPM arms front and rear and they seem to be alot softer and flex alot more. I never had shaft problems with the factory arms but I broke alot of those arms!.....Can't seem to win.. Only running - 1 degreeShow a pic of your setup maybe. And yeah you could probably limit the shocks that way, I did that with my rustler a looonggg time ago. Have you changed the camber settings at all? Cuz too much positive camber will likely cause this.
Hmmm that's odd. I don't know then. It don't think think its the shocks over extending as you say you didn't have issues with the stock ones.the only thing I upgraded is the arms. I went to RPM arms front and rear and they seem to be alot softer and flex alot more. I never had shaft problems with the factory arms but I broke alot of those arms!.....Can't seem to win.. Only running - 1 degree
That's freaking dumb, I did see that. You can still get some hd nylon rovan arms (black) on eBay tho!I might try the updated HD rovan arms but they as now only come in bright RED!. RIT dye should fix it!
No you are thinking of the gen 2 hd arms, the new gen 3 arms are all x braced like crazy and Dan from rovan does not have them in or listed yet. over in UK the stock for them is just in.That's freaking dumb, I did see that. You can still get some hd nylon rovan arms (black) on eBay tho!
Never see em?No you are thinking of the gen 2 hd arms, the new gen 3 arms are all x braced like crazy and Dan from rovan does not have them in or listed yet. over in UK the stock for them is just in.
Rovan Part# 85220 complete kit gen3Never see em?
not here state side. Look pretty good yes?
Well that is handy! Are those super stiff ? , Do you feel they are the best arms rovan has made to date. Must come on RTR kits and newer ones at that.It's what i have on mine, came stock with it 2 years ago. Don't know why they stop selling em separately ? I will say I have banged curbs and stuff pretty hard and they haven't failed. They are nylon so they flex pretty good ?View attachment 53616View attachment 53617
I'm not sure how it would compare to for say rpm or the normal thin hpi arms as I've never had em. These are the only arms I've had on this truck which I'd say is a good thing ? they aren't super stiff but they aren't Gunna twist eitherWell that is handy! Are those super stiff ? , Do you feel they are the best arms rovan has made to date. Must come on RTR kits and newer ones at that.
