D's HPI twin build
nice!
this is going to be epic!
what do you think to the fit and finish of the chassis doug?
It's ok jim.....? not gonna come out and say its perfect. I'm gonna have just run a drill bit through the tank hole mounts co the little plastic posts are just not fitting ? but don't think it's a big issue?? the Finnish is great??20191205_173016.webp20191205_174308.webp20191205_174403.webp
Mounted the tr steering thingy and irp turnbuckles??
Playing with the radio tray?? mounted my savox servos and full force braces ?? will have to move or make some plan with the on/off switch.........suggestions??
View attachment 55066View attachment 55067
make y self a nice slot with y foredom on the top off the radio box (y)nice n clean.
It's ok jim.....? not gonna come out and say its perfect. I'm gonna have just run a drill bit through the tank hole mounts co the little plastic posts are just not fitting ? but don't think it's a big issue?? the Finnish is great??View attachment 55063View attachment 55064View attachment 55065
I had the same issue with the radio box pegs on the rov when I installed my scorpion. thought it was cuz it was a rov but no :cautious: odd:unsure:
i reckon the holes are drilled then chassis gets bent ......holes change shape after the bend :unsure: (y)
I had to drill some of the holes out in my scorpion to on my last build. Fairly common with them
