yytw??
Pulled the trigger on a new car yesterday ??✔View attachment 56479
One like this 4WD 3.2 diesel ?
Pretty stoked.......just need to sit through the delivery time??
Not gonna go stupid ? with the wheel size in it 255/70/16 though of going 255/80/17??? so overall 1-2 inch more.✔ monster tires would look dumb???
Yip bought a mazda ?? 2019 plate run out ? was a very good price ?You bought a Mazda????
Me 79. 5.9l diesel swap sitting on 37s. Trying to find a pic of my 93. We used to 4wheel, quite a bit.
And what's wrong with a Mazda? It's just a rebadged ford. And everyone knows the OZ gets the best vehicles and the rest of us get poop on. Would have rather had the v6 diesel not the i5 but is a decent engine from what I gather. Should do decent on fuel too. Arnt you guys limited to tire size or something like that? Cant lift the trucks too high?
Standard lift here starts at 40mm ? not sure if there is a limit1?Arnt you guys limited to tire size or something like that? Cant lift the trucks too high?
9L/100✔i5 but is a decent engine from what I gather. Should do decent on fuel too.
This is true. My ford has a mazda badged 5speed in it. Came stock that way I think. It holds up fine to what I guess is about 350-400 hp, big tires, locked axles, and a heavy helping of leadfoot syndrome. Its getting a bit sloppy at 90k miles, but still works fine.Me 79. 5.9l diesel swap sitting on 37s. Trying to find a pic of my 93. We used to 4wheel, quite a bit.
50mm is the overall max limit here as far as 4x4 lift?? after that you have to have road worthy certificates ?Arnt you guys limited to tire size or something like that? Cant lift the trucks too high?
Beurocracy, the sworn enemy of freedom.?50mm is the overall max limit here as far as 4x4 lift?? after that you have to have road worthy certificates ?
2 feking right ? basically they say that the steering geometry and bump steer starts taking a hit after the factory parameters are changed? then to top it off all the states here have different thresholds ?Beurocracy, the sworn enemy of freedom.?
50mm max in Oz but you see a lot more on the roadStandard lift here starts at 40mm ? not sure if there is a limit1?
9L/100✔
The Mazdas here are a rebadged Isuzu D MaxMe 79. 5.9l diesel swap sitting on 37s. Trying to find a pic of my 93. We used to 4wheel, quite a bit.
yytw??
Nothing at all like a Ford.
The Ford here runs a 5 cyl 3.2 litre diesel.
They do handle significantly worse when you go real big on lift. That Mazda almost looks like the recently rereleased ford ranger hear in the states. I don't believe we have any small truck diesels here though. Usually its a pitiful gas job. You guys have better stuff.2 feking right ? basically they say that the steering geometry and bump steer starts taking a hit after the factory parameters are changed? then to top it off all the states here have different thresholds ???
yytw???
?yes. .yes they will?
