Armar5t
Active Member
- 40
Hey y'all. Been running my new 5t basically stock. I did do a dominator tuned pipe.
Looking for a rear suspension set up/ insight. Not trying to buy all the springs and shock fluid to figure out what combo is working.
Situation= tires are rubbing up in the wheel well and chassis bottoms out slamming on the ground. I added some more preload in the spring and now there is too much bounce in it and it still bottoms out on the smallest jumps/ bumps. Just trying to smooth it out a little bit.
I'm thinking 10 lbs springs and 50 weight shock fluid. Just not sure if its enough.
Thank you
Thank you
