Losi 5T RCMAX 50GT build
What next for the build?
  • Total voters
    14
Unfortunately one of the shocks has started to leak, I’m going to change the shock oil all round while I’m at it.
What weight would you guys recommend? I’ve seen people suggest 50wt for the rear and 70wt for the front, thicker at the front because it can be a be springy when all the weights at the back?
Another quick question, this throttle servo brace, would you say the servo should be underneath this or on top? The servo is on top at the moment but the brake rods are angled down and binding a little because the servo is much higher than stock :) Not sure if that's just how they are or its been fitted the wrong way around :)
