sounds like he is splashing $$$ while he waits for brps ? ?You bought the viper SC ??good luck with them
Do you not have 5b super spikes on your twin like mine?Hope they do hold out?? they work great on my twin???
View attachment 61103I hope they work for you, all the UK lads I know that run vipers on the 5ive use 5b spikes??
Hold up...theres different ones? Maybe that's the problem with fitment? Mine says for 5iveT though. HPI? Are the 5B wider? Are the the rears for 5b?I hope they work for you, all the UK lads I know that run vipers on the 5ive use 5b spikes??
Gotcha. Do they use 5ive wheels or 5b rear wheels?Yes mate the 5b are baja rears, the lads run them all round
Maybe that's what I should've did? Are the 5b tires the same height as the 5ive tires? But I couldn't use my pretty aluminum wheels?
I believe the baja 5b tires are 20 mm shorter than the Losi wheels, they are 170mm and the Losi /Baja 5t/SC are 190mmMaybe that's what I should've did? Are the 5b tires the same height as the 5ive tires? But I couldn't use my pretty aluminum wheels?
All electronics, screw kit, engine, and pipe. Everything else was there for the most part.Crucial what did you need to complete ur 5ive? I see you bought it for 450.
When the body didn't fit because of the pipe I flipped it while running it lightly?How heck did you bend a shock tower ??
