- 27,692
The rovan will do fine. Nice haul ?
It was so hard to buy rovan but thats the only one who had it??Cheaping out is not in my vocabulary?
Do it, mine is still holding together just fine. These plastics glue up very strong if you prep it well. I used the gorrila gel crazy glue.Don't feel too bad mate. I had to place my first Rovan order this week. I snapped a rear shock shaft end and lost the perch during a 40ft tumble and there were 0 genuine HPI rear 6mm shock shafts or spring perches to be found.
I'm gonna pull a 21BB and CA the shaft end together first, but I already needed the perches, so I'll give the rebuild kits a solid run through and at least keep them for backups.
The Rovan cage i was using on my twin rig could only be fixed at the front n rear the side fixings where a mile off?
Rovan does that to stay proprietary? All their own mismatches fit their stuff?I just put a clone tank on the bits baja and the holes on just line ?you have kinda do all the posts at ounce??????
I did some reading up and the Rovan X2 aren't that good and are the same price, something about diff's and bent chassis. Will see how this goes, my first NEW 5th scale. Mind my 5 year old son has his eye on it so guess its not going to be the last 5th purchase lolK mine was terrible, but that also might have to do with the fact that it was mounted to another rovan ???
Deal, where do I send the silver?I still got that yanmar ............
Ill give you 50 ouncesGonna need a bit bigger pile.....just got some big digger tires on the rear end ?
