C9A5B Baja build
I hear the small clutch will still slip with the bigger gearing. If you can I'd get the v3. Then you can run whatever gearing you want without issues .
That is incorrect. Your clutch will still heat up eventually and start to fade no matter what clutch if your over geared. Fact is, it's still only a 40cc. It cant pull tall gears for long periods of time.
Yes you can run the uber super spikes with a 40, I run it on my 40gt baja with no issues yet. They are also studded to hell
