- Nj
Well there you go thats one problem solved
Don't see why not. Everything off my rovan 30.5 for my obr/zen 30.5 lb. The shroud may be an issue but nothing a little cutting can't fixIm not sure your going to find another pipe brand for an exceed unless its a one off? I maybe wrong...and @Z.hb71 do you know if cy stuff swaps over to a zenoah LB
Im not sure. For a Baja it don't matter , and not sure about this rigI read that if putting a zenoah on a cy platform car that the fan shroud needs to be re used?
It's just fine. What I run in everything.Is 40:1 too little of an oil content? Maybe that destroyed mine.
Ya TOAST dude ! rebuild top end 20 min. jobhttps://www.nitrorcx.com/newrtrexrcba1.html
I just did yeah it doesn't pop out lol
Hey I got 2 real wt-1107's off my 2.0's that I swapped for sealed bearing models if you need cheap carb.
How cheap?
It is TOAST ~ no way it will be good after thatI’ll take a picture of the cylinder to see if it’s messed up too
