clutch carrier
enzo3856
Hey... so I need a clutch carrier...
Obviously there are some cheap metal ones on eBay. Should assume these are all chinesium?
That leaves me with two options from ddm...
Between these, which is best? Pros and cons?
I am on a total budget (laid off due to covid cutbacks)... I saw a turtle racing one also, but the listing says you need the whole TR system.. I am also in Canada, so add 30% to all these prices to feel what I am paying...
I am leaning toward the VP one right now...
Tr make an open bell carrier also 55??
but for that you need the tr bell, pinion and gear plate.
i have the vertigo on mine, great part (y) cant go wrong with either of those really, id just steer clear of the chineasium
So I got my parts in... Went with the vertigo...
AND... discovered another small issue... my brake hub is a little chewed for some reason (remember, bought this used) and the brake discs are wonky,,, the innner hex opening is no longer a hex.. so they are a little oversized on the hub... so they shift back and forth every time you hit the throttle.. and then they squish outwards... so that they end up thicker than they should be... so i think the brake starts binding... in the meantime i used a grinder to flatten them again, but i need a brake hub... out of stock at ddm.
Anyone know where I can find one?
Go with the rcmax 7075 one , can be found at Detroit performance RC ?
