ahhh the Swiss cheese mod...i caught that @Seandonato73 ?
Big time???? killed X2 motors now in one month?āSucks
Doubt that would change a thing.This is the only new thing ....in the mix?View attachment 64996
Give it a squirt of fuel down the ole plug hole and see if it will fart.
Put 990 ........nothing
Built it with a cy coil.....changed to a zen coil both had spark ........nothing
Tried that too ......nothing ?ā![]()
Still no pop?āHow about dumping a little oil in the cylinder...if it starts then its compression related
Yep she done ?Still no pop?ā?
Yea im gunna say its done as well
Sorry for not skimming to see what engine brand you have @dougstar is it a real engine or clone?...one thing I lived by with 2 strokes is that any day at anytime you can blow these engines.. and im ok with that and im prepared to rebuild every time I run my rig
Zen 32Sorry for not skimming to see what engine brand you have @dougstar is it a real engine or clone?...one thing I lived by with 2 strokes is that any day at anytime you can blow these engines.. and im ok with that and im prepared to rebuild every time I run my rig
Nah not yetYou got a bad string of luck, or your not doing something quite right mate, normally they are quite reliable engines... with some exceptions of course. Doug's just having a rough go of it here late.....
Doug, did you pull the top off and have a look yet?
