It's a Sanwa rx37w , says 4.8-6.0v ?What receiver isn't rated for HV? What are you using Z, AM crystal transmitter??
Damn, thanks Mr C ?. Guess I read the wrong thing then ? so that's fine. Now I'd just need a battery and new servos.This is what I foundView attachment 65047
Is the reciever rated for high voltage?
Neither would I, he'll only end up braking something ?Wouldnt tear an engine down that works fine....
Oi fek you mark ?????Neither would I, he'll only end up braking something ?
Yeah idk if I will ? I would just pull the head, not split the cases.Wouldnt tear an engine down that works fine....
?the fek does that even mean?It runs fine, don't mess with it you dink....
Your thicker then a fricken brick wall.?the fek does that even mean?
My ass is ???Your thicker then a fricken brick wall.
Right ?It means " if it ain't broke don't fix it"???
